VCDS Vw UP
18/09/2021, 21:40 (Resposta editada pela última vez em: 18/09/2021 21:40 por freddqueiroz.)
Resposta: #191
RE: VCDS Vw UP
OPa!
Fui tentar fazer essa modificação que voce passou aqui, e não sei no que mexi, ta dando erro de code... não funcionou nenhum dos numeros que voce indicou. estou com esse erro agora:
1543 - Control Module Incorrectly Coded
U1014 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 146
Mileage: 34660 km
Date: 2042.14.14
Time: 20:40:26
Voltage terminal 30: 12.4 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
Meu Up é um move TSI 2018. Será que voce consegueria essa linha do módulo 5F como tá no seu pra eu comparar com a minha!?
(02/04/2020 15:46)andrescharam Escreveu:  Esqueci de postar aqui, mas consegui realizar a alteração depois de revirar foruns de outros países. Ao verificar o código do Composition Phone de um dono de E-UP consegui identificar o byte diferente e consegui os demais códigos. Fiz através do OBD Eleven, e efetuei os seguintes passos:
-Entrei na unidade 5F , fui em codificação longa e alterei o byte número 18, que por padrão vem 00. Ao alterar esse byte, tem os seguintes resultados:
01 - Cross
02 - Blue Motion
03 - E-up!
04 - Eco up!
05 - Beats Audio
06 - Sound
07 - Allstar
08 - Rline
09 - Spice
10 - GTI
28/04/2022, 01:06
Resposta: #192
RE: VCDS Vw UP
Boa noite galera, sou novo por aqui, venho buscar a ajuda de vocês com uma situação. Possuo um cross up tsi 2017/18 no qual veio com o radio mais simples de fabrica, no inicio do ano adquiri um kit do composition phone pelo ml e arrumei uma empresa pra instalar, foi instalado mas o sensor de ré nao funcionou no radio, apenas funciona de forma sonora (mas funcionava no radio básico), o instalar disse que é porque o composition veio da versão 2020 na qual nao tem sensor de ré e por isso nao funciona. Porém, essa semana de forma muito misteriosa e de forma única (nao consegui mais replicar o feito) funcionou o display exibindo o nível de sinal, mas infelizmente foi uma única vez e dps nao se repetiu mAis.
Gostaria muito que o sinal fosse exibido no composition, alguém teria alguma luz? Será que realmente por ser retirado de um 2020 não irá funcionar? Eu teria que comprar um composition 2019 por exemplo? Ou é algo que via vcds resolve?
28/04/2022, 16:22
Resposta: #193
RE: VCDS Vw UP
Qual valor em média do VCDS???
28/04/2022, 16:37 (Resposta editada pela última vez em: 28/04/2022 16:41 por canardo.)
Resposta: #194
RE: VCDS Vw UP
Desculpem galera, acessando pelo link direto para acompanha aqui, acabou duplicando a minha postagem e infelizmente nao tenho permissão para remove-la.
Respondendo o amigo a cima, acredito que cada lugar tem seu valor, em ribeirao preto paguei 150, aqui na minha cidade ja esta em 350.
29/04/2022, 16:21
Resposta: #195
RE: VCDS Vw UP
(28/04/2022 01:06)canardo Escreveu:  Boa noite galera, sou novo por aqui, venho buscar a ajuda de vocês com uma situação. Possuo um cross up tsi 2017/18 no qual veio com o radio mais simples de fabrica, no inicio do ano adquiri um kit do composition phone pelo ml e arrumei uma empresa pra instalar, foi instalado mas o sensor de ré nao funcionou no radio, apenas funciona de forma sonora (mas funcionava no radio básico), o instalar disse que é porque o composition veio da versão 2020 na qual nao tem sensor de ré e por isso nao funciona. Porém, essa semana de forma muito misteriosa e de forma única (nao consegui mais replicar o feito) funcionou o display exibindo o nível de sinal, mas infelizmente foi uma única vez e dps nao se repetiu mAis.
Olá amigo.
Acredito que consiga resolver com a programação, pois os VW up 2020 tinha versão com sensor traseiro (Connect não tinha e Xtreme tinha), eles não iriam ter 2 aparelhos diferentes pra isso, no caso deveria ser tudo programado para o carro com/sem sensor traseiro.
29/04/2022, 20:38
Resposta: #196
RE: VCDS Vw UP
Sabe me dizer quem faria esse serviço na região de sao paulo ou remotamente?
21/09/2023, 08:14
Resposta: #197
RE: VCDS Vw UP
(28/10/2015 08:52)LeoBA Escreveu:  Amigo, poderia ensinar como configurar essa função no próprio aparelho?
Bom dia jovem, se voce for no menu do som, vai encontrar as opções de antena, lá term 3 opçoes. A 3° desliga o som na Ré, a segunda aumenta os bips e a primeira é a original.
No manual do veiculo tambem fala sobre...
19/03/2024, 18:28
Resposta: #198
RE: VCDS Vw UP
Pessoal, onde dá para conseguir os códigos de fábrica da ECU (injeção eletrônica) do up tsi?
16/07/2024, 09:11
Resposta: #199
RE: VCDS Vw UP
Alguem tem o tutorial de como ativar o coming leaving home no Up! Move 17/18, sem o botão AUTO?
30/07/2025, 16:57
Resposta: #200
RE: VCDS Vw UP
(19/08/2018 13:28)Re_Nato Escreveu:  E aew pessoal!
Estou em uma guerra para instalar um volante multifuncional, fiz a instalação física do volante mais as fiações, mas estou tomando um cansado da programaço da central elétrica para reconhecer o volante que não responde na opção 16.
Leitura da Central elétrica:
"Wednesday,15,August,2018,23:34:06:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.2.0.3 (x64)
Data version: 20180212 DS287.0
http://www.Ross-Tech.com
VIN: 9BWAH4121GT522381 License Plate:
Address 09: Cent. Elect. Labels: 34D-937-087.clb
Control Module Part Number: 34D 937 087 D HW: 34D 937 087 D
Component and/or Version: BFM Hp 122 0105
Software Coding: DFC5C10E07008F2F2D01996D900100221117
Work Shop Code: WSC 03310 453 00230
ASAM Dataset: EV_BCMBFMHella 003001 (VW12)
ROD: EV_BCMBFMHella.rod
VCID: 3169A3C678295CCCA7-8065
3 Faults Found:
212996 - No Communications with Anti-Theft Sensor
U10F4 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 63830 km
Date: 2034.14.14
Time: 23:31:11
214540 - Local Databus
U1030 00 [009] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 63830 km
Date: 2034.14.14
Time: 23:31:13
214784 - Local Databus
U1125 00 [009] - Additional Installations Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 63830 km
Date: 2034.14.14
Time: 23:31:11
Alguém manja de como fazer a central reconhecer o volante?
Obs.: Eu já tentei ativar o Bit 3 no Bity 9 e não funfo.
Valeu!
Alguém conseguiu fazer essa proeza? Vou tentar no meu cross TSI 2017, esperando chegar o cabo e o volante
  Diferença VCDS curious666 0 2.874 24/10/2023 00:20
Última Resposta: curious666
Piscada Alguém do RJ que possui o cabo VCDS? Bruno Crespo 5 11.345 24/01/2018 08:55
Última Resposta: Bruno Crespo
