ABORTION PILLS ON SALE IN TZANEEN+27 63 034 8600
21/06/2026, 19:38
CHEAP,LEGAL ABORTION PILLS ON SALE+27 63 034 8600
OUR BRANCHES ARE IN PRETORIA AREAS,RANDFONTEIN,MABOPANE STATION,SOSHANGUVE,MABOPANE,HATFIELD,BROOKLYN,SUNNYSIDE,ARCADIA,MENLYN,MENLO PARK,SOWETO,MIDRAND,TEMBISA,ATTERIDGEVILLE,LAUDIUM,WEST PARK,DANVILLE,DURBAN,NEWCASTLE,PINETOWN,TZANEEN,ZEERUST,MAFIKENG,BLOEMFONTEIN,PI​ETRMARIZTBURG,CAPE TOWN, DURBAN, JOHANNESBURG, KIMBERLY, NELSPRUIT,POLOKWANE, PE AND RUSTENBURG
WE ALSO DELIVER ABORTION PILLS ALL OVER THE WORLD
24 Hr Appointments, Booking and Deliveries Call +27 63 034 8600
A private abortion means avoiding the bureaucracy of NHS. It’s your choice to have a child. And only you can make that decision
.... Call Dr. Desire today
NON-SURGICAL ABORTION - (MEDICAL ABORTION)
WHAT IS ABORTION PILLS?
The abortion pill should not be confused with the morning after pill as it is intended for use within the first 12 weeks of pregnancy whereas the morning after pill should only be used within 3 to 5 days after intercourse. The abortion pill, mifepristone and misoprostol, is an approved pregnancy termination method in South Africa and can only be prescribed by a medical doctor.
How DOES ABORTION PILLS WORK?
Both abortion pills, mifepristone and misoprostol, are usually used in order to terminate a pregnancy. Mifepristone causes the embryo to detach from the uterus thereby cutting off essential nutrients and oxygen carried by the blood. Misoprostol is then taken two days later and triggers the evacuation of the embryo remnants through the vagina. This often appears as a heavy period.
It is advisable that you consult with your medical practitioner for a further understanding of how the abortion pill works.
IS ABORTION PILLS SAFE?
The abortion pill is usually safer than a medical abortion or surgical abortion but should only be considered in the first 12 weeks of pregnancy. Like any procedure, use of the abortion pill can result in complications but if used under the supervision of a medical doctor, the chances of complications are greatly reduced. Your doctor will be best suited to handle any complications should they arise.
DANGERS AND SIDE EFFECTS OF ABORTION PILLS?
Common side effects include abdominal pain, cramping, bleeding and spotting for up to 2 weeks after using the abortion pill. Other side effects that may occur include drowsiness, nausea, vomiting, diarrhoea, fatigue and fevers. Side effects may not occur in every case and if you are experiencing any symptoms that are persisting, you should consult with your medical doctor immediately
the abortion pill may cause a disturbance in your normal menstrual cycle in some users but usually there are no significant dangers associated with using the abortion pill. However, using the abortion pill without the supervision of a medical practitioner or after 8 weeks of pregnancy can be dangerous. Uncontrollable bleeding, severe cramping and infections can arise without correct supervision and for this reason; you should never buy or use the abortion pill from illegal sources.
Always consult with your doctor or a qualified staff at a family planning clinic before you commence with any abortion method. Call/ WhatsApp Dr Desire John Tobo on +27 63 034 8600 or drdesiretobo@yahoo.co.za , drdesiretobo@gmail.com
  ABORTION PILLS FOR SALE IN KWA-THEMA+27 63 034 8600 drdesire 0 128 21/06/2026 19:52
Última Resposta: drdesire
  +27 63 034 8600 Women sexual dysfunction, women sexual performance products drdesire 0 128 21/06/2026 19:49
  ABORTION PILLS IN SASOLBURG+27 63 034 8600 drdesire 0 132 21/06/2026 19:45
  Abortion and womb cleaning pills in Durban+27 63 034 8600 drdesire 0 129 21/06/2026 19:43
  PAIN FREE ABORTION PILLS IN CRESTA+27 63 034 8600 drdesire 0 129 21/06/2026 19:41
  Safe abortion pills in Johannesburg+27 63 034 8600 drdesire 0 126 21/06/2026 19:39
  Abortion pills in Bronkhorstspruit+27 63 034 8600 drdesire 0 126 21/06/2026 19:36
  Raw Gold bar Nuggets +256790560642 Gold Dust Rough Diamond for sale Spain Argentina maiulanah 3 505 26/05/2026 20:32
Última Resposta: makamu
