How to Choose Forza Horizon 6 Starter Cars | U4GM
03/06/2026, 00:08
The first car choice in Forza Horizon 6 can feel bigger than it is. Mei lets you drive one of three cars to the festival, but you're not locking your save into a single path. All three end up in your garage, so think of the pick as your first driving mood rather than a permanent build decision. Still, because these starter versions are tuned better than their basic dealership copies, they're worth keeping alongside your wider FH6 Cars collection instead of selling them for quick credits.
Quick guide for the first hour
You'll notice the difference between the three cars almost straight away. The Toyota Celica GT-Four feels safe and planted. The Nissan Silvia K's asks for more throttle control, especially if you like sliding into corners. The GMC Jimmy is the rough-ground bruiser, quick off the line but not exactly graceful on tight roads. Here's the short version before you start comparing every stat.
Pick the Toyota Celica GT-Four if you want an easy all-round starter.
Pick the Nissan Silvia K's if you enjoy drifting and rear-wheel-drive control.
Pick the GMC Jimmy if you'd rather smash through dirt, hills, and open terrain.
Starter car comparison
The three cars all sit in C Class at PI 500, so the game presents them as balanced. They don't drive the same, though. The Celica has the best mix of road pace, grip, and rally comfort. The Silvia is lighter in feel and better for players who like rotating the car with the throttle. The Jimmy wins on torque, launch, and off-road grip, but it can feel clumsy when the route gets narrow.
Car
Main strength
Best early use
Watch out for
Toyota Celica GT-Four ST205
AWD balance and mixed-surface pace
Road races, rally routes, exploring
Not the strongest specialist
Nissan Silvia K's
RWD control and drift potential
Drift zones, street corners, flowing roads
Weak braking and less forgiveness
GMC Jimmy
Launch, torque, and off-road traction
Dirt, stunts, open-country events
Heavy feel and low road handling
Which one should you actually drive first
If you're new, or you just don't want hassle, take the Celica. It's the car that makes the fewest demands on you. AWD saves messy corner exits, the handling is steady, and it won't panic when the race leaves clean tarmac. The Silvia is more fun if you already like oversteer. It'll teach you throttle discipline fast, sometimes the hard way. The Jimmy is brilliant when the route gets wild, but on tighter road events you'll be fighting weight and body roll more than rivals.
Why you shouldn't dump the starters later
A common early mistake is treating these cars like throwaway tutorial rewards. Don't. Mei's versions are already set up better than the plain models, and that makes them useful well after the opening drive. Keep the Celica for mixed events, save the Silvia for drift practice, and pull out the Jimmy when the map turns messy. Once you start building a broader garage, upgrades and money matter more, and players who want to speed that up may look at Forza Horizon 6 Credits for sale while planning their next proper race build.
  Best Forza Horizon 6 Accounts for Competitive Racers lOGaNKInG708 0 96 07/06/2026 23:56
Última Resposta: lOGaNKInG708
  U4GM on Where Diablo 4 Seasonal Progress Moves Andrew736 0 123 06/06/2026 05:57
Última Resposta: Andrew736
  Why GTA 5 Players Trust U4GM for Mission Prep Andrew736 0 106 06/06/2026 05:54
  U4N: How to Farm More Super Wheelspins Without Buying Cars FrostPhoenix 0 106 05/06/2026 23:15
Última Resposta: FrostPhoenix
  Where to Start poe2 Runes of Aldur Challenges | U4GM Hartmann846 0 137 03/06/2026 05:41
Última Resposta: Hartmann846
  U4GM: How to Find and Use ARC Motion Cores in ARC Raiders Blustery 0 135 02/06/2026 22:47
Última Resposta: Blustery
  How to Get Rare Cars Like the Nissan Safari Turbo in Forza Horizon 6 lOGaNKInG708 0 164 26/05/2026 03:05
  How to Complete the Restrictor Plate Challenge in Forza Horizon 6 FrostPhoenix 0 902 25/05/2026 22:44
  Dodge Charger R/T Spawn Points in Forza Horizon 6 lOGaNKInG708 0 141 22/05/2026 03:58
  Forza Horizon 6: Discover Hakone Nanamagari Touge Race Secrets lOGaNKInG708 0 133 22/05/2026 03:33
