Granny: Can You Escape the Creepiest House in Horror Gaming?
Ontem, 05:30
If you love horror games that make your palms sweat, your headphones feel dangerous, and every dropped object seem like a life-changing mistake, Granny is a must-play. Developed by DVloper, this indie survival horror phenomenon turns a simple idea—escape a locked house—into a tense, addictive game of stealth, puzzles, and panic.
Originally released for Android in November 2017, Granny quickly became a massive hit thanks to its simple controls, frightening atmosphere, and memorable villain. It later arrived on iOS and PC, introducing even more players to the terrifying rule of the house: Granny hears everything.
You have five days to escape. Can you make it out before she finds you?
1. What Is Granny?
Granny is a first-person survival horror game created by Swedish indie developer DVloper, also known for other horror titles such as Slendrina. The game places you inside a dark, decaying house after you have been captured by a sinister old woman known only as Granny.
You wake up in a locked bedroom. The front door is heavily secured. Windows are barred, rooms are filled with traps, and useful items are hidden throughout the building. Your goal is straightforward: find the tools, keys, and clues needed to escape.
The problem? Granny patrols the house constantly.
She reacts to noise, investigates suspicious sounds, sets traps, and attacks if she catches you. Every mistake can bring her closer. Drop an item, step on a creaky floorboard, knock something over, or accidentally make too much noise, and she may come running.
That combination of simple objectives and unpredictable danger is what makes Granny so effective. You are never completely safe—not even when you are hiding under a bed.
2. How to Play Granny
Start by studying your room
When you wake up, do not rush out immediately. Look around the starting room and check drawers, shelves, and corners. Important objects can appear in unexpected places.
Pay attention to any exits, hiding spaces, and possible routes away from the room. Knowing where to run when Granny enters can save an entire day.
Search every room methodically
Granny’s house is packed with hiding places for items. Open drawers, inspect cabinets, look behind furniture, check shelves, and investigate small compartments.
Try to remember where you have already searched. It is easy to panic and waste time revisiting empty rooms while Granny is nearby.
Learn which items matter
At first, you may find objects that seem confusing. Do not throw them away randomly. Most items have a purpose, even if you do not yet know where they belong.
If you find a key, tool, or mechanical part, place it somewhere safe that you can remember. Avoid dropping important items in dangerous hallways where Granny may hear them or where you may struggle to retrieve them.
Keep your noise under control
Noise management is the most important skill in Granny. Every action should be deliberate. If you must drop something, make sure you have an escape plan.
Sometimes you can even use noise to your advantage. Dropping an object in one area can lure Granny away from another route. This is risky, but it can create a valuable opening.
Always know where to hide
Before searching a new room, identify the nearest hiding spot or escape route. Is there a bed? A wardrobe? A nearby door you can close behind you? A staircase you can use to change floors?
Do not wait until Granny is approaching to make a plan. By then, panic will take over.
Listen carefully
Sound is a major part of Granny’s gameplay. Wear headphones if possible. Listen for footsteps, doors opening, traps activating, and Granny’s movements.
If you hear her getting closer, stop searching. Hiding for a few seconds is better than losing an entire day.
3. Useful Tips for Escaping Granny’s House
Use Practice mode first
The fastest way to improve is to learn the house without the pressure of Granny’s pursuit. Explore every floor, test doors, identify puzzle locations, and memorize useful hiding spots.
Do not carry items unnecessarily
Carrying an item can be risky. If you are caught, you may lose your chance to place it safely. Move objects with a purpose: take them directly to where you need them, or store them in a memorable safe location.
Watch for bear traps
Granny’s bear traps are easy to miss in dark areas. Move slowly through doorways and avoid sprinting blindly through rooms. If you step in one, Granny may hear you struggling.
Close doors behind you
Closing a door can buy you a few seconds and make Granny’s path less direct. It is not a permanent defense, but in a chase, every second matters.
Use distractions wisely
A noise can pull Granny away from a valuable area. If you need to explore upstairs, creating a sound downstairs may give you a temporary advantage. Just make sure you are not standing beside the distraction when she arrives.
Stay calm after being spotted
Getting spotted does not always mean the day is over. Run through familiar routes, close doors, change floors, and hide only when you have broken Granny’s line of sight. Panic leads to mistakes; a clear route can save you.
Expect item locations to change
The placement of objects can vary between games, which keeps Granny from becoming too predictable. Do not rely entirely on a walkthrough. Learn item functions and house routes instead.
4. Are You Ready to Escape?
Granny proves that a horror game does not need a giant map or blockbuster budget to be unforgettable. With one creepy house, a terrifying antagonist, smart sound design, and plenty of puzzles, DVloper created a horror experience that continues to frighten players around the world.
Whether you are a horror veteran or a curious newcomer, Granny offers a fun challenge that is easy to start and difficult to master. Explore carefully, move quietly, remember your hiding spots, and never underestimate a harmless-looking old house.
Ready to test your nerves? Visit Granny Horror, start your escape attempt, and see if you can survive all five days.
Just remember: do not make a sound.V
  Snow Rider 3D – The Ultimate Winter Escape You Didn't Know You Needed! Nuguse Hamid 0 85 21/07/2026 04:41
Última Resposta: Nuguse Hamid
  Escape Cano Reto Up TSI Felipe Furlan 17 26.363 13/07/2026 22:17
  Escape up tsi Phoenixdriver 28 67.813 25/02/2020 01:19
Última Resposta: rubenssn
  Tempos de Admissão/Escape do motor ArtFell 6 15.807 17/05/2017 17:12
Última Resposta: ArtFell
  Luz Deficiência do Siatema de Escape Shumacher 5 30.488 04/03/2016 09:59
Última Resposta: Shumacher
